I have a 2011 linhai Bighorn atv 200 it looses power at half throttle and beyond and of course the rpm's drop,I've replaced the cdi, coil,stator,regulator and the Carb,still have a problem
is it getting enough fuel ?
Yes,just discovered a vacuum line that was partly unconnected this seems to have taken care of the rpm problem ,now it's being hard to start, I am charging the battery and cleaning the air filter,hopefully that will take care of the remaining issue.
Sorry I had some other pressing matters , rechecked the valve lash intake .005 , exhaust .008 as given to me by another source , since my last post I have found one main vac. line came off , so I put it back and found that took care of the hi rpm issue also figured out the air filter needs replacing as it will not run with the filter on ( you can see the filter flexing ), the problem now is when the bike gets warmed up it will run rough then stall out re start once or twice then wont restart again until it has cooled off , someone told me it could be a bad ring but I"m just not sure , sounds more like something electrical even though the stator, CDI, coil and spark plug have been replaced , what do you all think ?
Thanks for the input , after checking compression cold and hot I found a difference of 26 psi , after removal of the comp. cylinder and the piston I found damage to the piston skirt and fine groves in the cylinder wall ( deep enough to catch your fingernail on) .After replacing all the electrical components and the carb. I am hopeful that replacing the piston ,rings and cylinder will take care of the problem , I will also be checking the oil screen and eventually the oil pump. When I get it back together Ill update this post.
    • By Adamb2025
    • By ButchM
    • By dkgg5755
    • By 97kingquad
    • By davefrombc
      Anyone  carrying  a power box when  camping with their ATV?  I built  a custom  one.  I  used a  marine  battery box that  has 2  50A Anderson Grey connector  outputs (  changed one of the greys to a red), an accessory socket  and2  USB outlets,and a battery  voltmeter ..  I  added a Pure sine wave 1,000w inverter to it and A red 120A Anderson connector to the  output  posts.. To  charge the  100Ah LiFePO4 battery  I  put in the box, I added  a DC to DC charge adapter that I  made input connectors for to allow charging the battery from a vehicle's  accessory socket  or a solar panel.
      It  was a fun  project.. Besides  having a  1,000w power box for  120V ac , USB   and  12v accessories using the 10 A socket.  I  have  50  A  Anderson connectors  and the 120 A connector  to run  things like a  12v electric outboard   for fishing  trips .  The LiFePO4  battery  only allows a max output of 100A  so  it  can't be used for something like jump starting,  but  it  is half the weight and  delivers twice the capacity of a lead acid battery running accessories..  Commercial pow2er  boxes  don't  deliver  high draw 12v output to run things like  the  electric outboards.   That's one reason  I  custom  built  mine.   One box that serves for both camping and fishing.
