1987 suzuki LT230E, manual shows the plug on the underside of engine. Not there. There's an access hole in the skid plate, but no plug. I see a possible plug on the backend of the engine case. Its not underneath but on the low part of the case. Facing the swing arm. Is that it?
Edited by thesandmanisme
that mite b the fill plug, sometimes the skid plate will cover the plug ,if u hav enough clearance u mite get a good lite an a mirror an c if u can spot it ,on the flip side u mite hav 2 take the skid off.
OK. That's easy enuff, or so it would appear. Thanks for your response, I appreciate that.
I removed the front skid plate bolts and let it swing down. The only bolts on the bottom of the case, are the 3 small ones that hold a square plate underneath the oil filter area. The only other place I can think, is on the lower rear case next to the reverse gear sending unit. Its a 17mm bolt with a brass compression washer. It's just strange to me that it's not on the underside. It is low on the case though.
Is the repair here as simple as;
1. Removing the skid plate.
2. Taking the oil drain cover off
3. Replacing the cover and bolt
4. Carefully reattaching the oil drain cover to the case (I know there is an O ring in there etc.)?
notice #2 take DRAIN COVER OFF
Edited by crookedbandit
left out something
Does the drain cover have 3 bolts?
    • By kevinohio
    • By buriedpast
    • By Yamahahahaha
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
