my son has a 50cc Baja atv automatic trans that at time (right now) jerks then dies, once he trys to start it the starter causes the quad to lunge forward like the clutch is not releasing. when this happens, you cannot push the quad backwards either even with the engine off. if you raise the rear on a block it will start but the rear wheels will spin even at idle, if you pull the quad off the block the load of the machine will instantly kill the engine. im guessing its a stuck clutch issue however I cannot find any info anywhere. im an ase master auto tech so I am pretty mechanical just need a point in the right direction. any help would be greatly appreciated. thank you in advance!
Dana
Get into the clutchs and see whats wrong.
Find a site with a fiche so you know how it is supposed to be.
Being a mechanic, I feel you will be fine. :)
Hmmm...makes sence.. Thats what you recommend to your auto customers right..
~no reason to change your oil , itll come apart and well change it then~...j/k. LMAO :D
    • By realpilot
    • By logray
    • By OldATVowner
