Nascar!!!
By p5200
By kawasig
I have a 1987 Suzuki dual range 230 and a 96 bayou 220. I'm trying to figure what oil to use. I normally put Amzoil synthetic in most everything. But I understand there are concerns over the wet clutch. I've heard rotella 10w40 full synthetic,5w40 synthetic,10w30&40 non synthetic. I do live in Michigan, so temps cold and hot are encountered. It could be below zero or 90 degrees farenhight. I don't have manuals for them. Any help is greatly appreciated!
By Jhb12686
Hello I appreciate the welcome into the group. I am beyond frustrated with this desperate search for parts. I have a 2013 XY power sports UTV 300. I had a catastrophic failure in my rear differential which resulted in the destruction of almost everything inside. I have located everything I need to completely redo the rear end. But I cannot find a short side axle shaft with six splines etc. it's an offset differential and one shaft is longer than the other and I need the short one. The tip of it broke off (pic). Any help in getting another shaft for this thing would be GREATLY appreciated. Thanks guys
By rgeiser
just wondering if i pay the thirty dollars how soon will i be able to access the manuals?
By Otter9099
I have a 1996 Suzuki Quad Runner 250 LT-4WD. What tools should keep on the atv at all times incase of break down for a trail fix? Share what you carry and share pictures if you can.
