    • By gohndd
      Hey guys, I have a 1999 king quad. The right front brake locks up when I squeeze the lever. I can loosen bleed screw, fluid will come out and it unlocks. I'm thinking maybe wheel cylinder. Any suggestions?
    • By mmabry55
      My front wheels are constantly locked making steering extremely hard. I took the diff apart and it looks like it won't allow the front wheels to turn independently. Is this the norm? I have 27" paddles and it's almost impossible to steer while driving slow.
    • By Dan Kroes
      Does anyone know if there is a tool for torquing the bearing nut and jam nut on Polaris solid rear axles? Seems like it must exist if factory says 150 ft lbs. What would it be called?
      I just recently acquired a 2004 Suzuki Eiger it will crank and run, but the wheels are locked, I took the drive shaft loose and the wheels will now roll so I know its not the rear end or brakes.. The neutral light is on and when I shift gears neutral light goes off but then comes back on . The reverse high and low shifter was stuck but I got it freed up but doesn't seem to do anything and does not move freely, never had one of these, but I would think that there should be a click when it locks in gear this just moves  no clicks.. The foot shifter feels like its working or maybe I should say not stuck, but never goes in gear. I can see that the left side cover has been taken off at some point and it has a new shift linkage. Im suspecting that something isn't right in there. Any ideas would be greatly appreciated.
