How old to start with ATV
By Jdeaton011989
By quadcrazy
Best ATV for Older Riders
Polaris Sportsman 570 EPS
Best Reliable ATV for Seniors
Honda FourTrax Rancher EPS
Best Features
Best Premium Comfort ATV
Can-Am Outlander MAX
Standout Comfort Features
Best ATV for Easy Handling
Suzuki KingQuad 500AXi
Why Older Riders Like It
Yamaha Grizzly 700 EPS
Best Features
Arctic Cat Alterra 600 TRV
Key Advantages
Electric Power Steering (EPS)
Automatic Transmission
Lower Seat Height
Two-Up Models
Hand Warmers and Heated Grips
Adjustable Suspension
Buying Too Much Power
Ignoring EPS
Choosing Aggressive Tires
For most mature riders:
Final Thoughts
By middlebrookgt
By alexwv1863
I'm currently working on an 04 Suzuki Eiger 400 and ran into some issues. Main issue being it's really hard to start. Once I get it started, it runs bad. Sounds like it's missing, which I'm pretty sure is an idle issue. It's not my 4 wheeler. I'm working on it for a buddy. Someone started working on the original carb and 2 jets were missing when I got it to work on.
So, I ordered a new carb. To get it to run, I had to adjust the throttle screw on the handle bar almost all of the way out. Even doing that, it still sounds like it's bogging down and missing.
I did put a gas filter on it, which I'm questioning whether or not that's the issue and it's not getting enough gas like it should. The petcock only has an On, Reserve, and Prime option. It also has 2 ports. I guess I have the hoses hooked up right. There's no way to shut the gas off completely, and also it looks like there's no gas getting thru unless I run it on Prime. Reserve drips gas. I'm going to take it apart today and clean it. I'm also going to take the jets I need out of the new carb and put in the old one.
I don't know what all this person did you the 4 wheeler before I got it. There's odds and ends missing that I've noticed so far. What else can I try or look for? What could be the gas issue with the carb and petcock? The carb was completely off the bike except hanging onto the throttle cable. The diagram I found for the carb doesn't help me with hose placements. Any help, or questions would be appreciated. I can attach photos if it would be of help.
