Guest Patrick Rawls
Working on 94 4x4 polaris magnum. Is the red wire at voltage reg hot at all times or just when key is on. New to forum please hang with me
Guest Patrick Rawls
Neghbor bought 94 polaris magnum 4x4 used , not charging, red  wires coming from junction box at rear of unit are not hooked to anything , kill switch is now wired into a toggle switch, start button has also been replaced. Please help with any info ,will be greatly appreciated.
You can download a copy  of the  service manual   here: http://www.mediafire.com/file/oj3p8rysdnv921n/1985-1995_Polaris_Atv_Service_Manual_Repair_All_Models.pdf
You  should be  able to  find  the  wiring diagram there. . I  don't envy you the task  of tracing the  wiring   on a butchered  system.
It  is  just over  100  MB ...a little  more than 1 MB over the  file size limit for posting  to the Quad Crazy  manual  library.
Edited by davefrombc
Guest Patrick Rawls
Okay thanks ill try that, don'tknow what the two red wires coming from the junction box at the back of the quad, another one goes too the battery   the other two ??? Thanks again
    • By LashinWheeler
      Any help would be great,
      Thanks!
    • By cruteg8
    • By flyinbrian365
      What's Covered:
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      Polaris 110 EFI engine repair
      Brake system repair
      Polaris ATV torque specs
