I bought a 1987 Kawasaki KLF atv
By Gwbarm
I have noticed lately that the ATV tires i generally buy have upped in price quite a bit. The Kenda EX that i generally get are sold out and not available at this time, the EVO which is usually my second choice has increased 50.00 on a set of 4. The HTR Kendas best tire is now 150.00 per tire. Even the Sun F have increased but not so much as the others.
By docdoug72
Has anyone had a suzuki 230 quad lock the engine up? Its a well maintained bike, it locked up when my son was riding it. Pulled the plug, it has connected with the piston. I'm thinking the con rod let go. I don't have a service manual. Does the engine need to come out to check further?
By Atomusthenes
By kawasig
By Gwbarm
