2018 Yamaha Kodiak 450 4X4 Specs
By hengstserepair
Nuetral: Runs as expected
Lorne
By Rockbottom
What should i test next?
thanks ahead
By Mister907
By jeffinotown
Hey guys and gals. I've been working on my friends 2007 big bear IRS. Unfortunately after 3 different people got their hands on it and only made things worse every time. After months of finding just crazy problems everywhere. I'm finally at the point we're its almost 100% !!! But I'm getting a short somewhere between the 4xW switch I believe. I managed to by searching the internet like a fiend, got my hands on an official Yamaha wire harness for the year and make. But I don't have the numbered component list and to be honest. After hours of going through and making everything so it's easy to reference. If anyone has a picture of the referenced components. I would be forever in your debt. I've spent hours marking up the blown up diagram so it will be easy, for any possible future repairs. Please and thank you. Here's a picture of what i have so far. Unsealed it in plastic so oil and crap won't spill or get smudged. This damn things worth it's weight in gold. Thanks Jeff 2007 Yamaha big bear 400 IRS. YFM40FBW
By crankin
