Hi i have a honda 350es 2002 4x4 (same as rancher but canadian edition). My problem is the clock and trip meter always resetting when i power off the bike. The trip meter reset to 0.0 and the clock flashing 1:00. The other function work normally gear shift, hourmeter and odometer. If i power off the bike for approx 2-5 seconds the clock and trip meter didnt reset. The battery is ok and all the fuse is ok. Can someone help me with this problem please. I found anything in my service manual.
thanks
  • 3 years later...
wow, you have this issue from 2017 and still no fix? I would think that there is an issue with getting power with key off to the trip meter unit. when you shut it off, it resets. I would try tracing wires to see. Get a wire diagram.
yes i have this problem since 2017 it's not a big problem but it's annoying. No wire problem and no switch problem. I'm thinking is the cluster board itself, but i dont want to change for just this problem. Thank you for your reply
    • By Cj Winds
    • By oztrax
      MAX 4 6X6 2008
    • By 88classic
      I have (2) sets of brand new plastics available for Honda Rancher 420 2014-2023. These are genuine genuine OEM Honda plastics. One set is white and the other set is green. The boxes these are in are too big to ship.(Unless you want to pay for it. If so, lookup your own shipping rates from 17325 and box size is 58"x35"x18").  $400
