You can use other muffler if you can do some welding or get it attached. However depending on the exhaust, you may need to jet the carb. What exactly are you looking to do? Put something on like an aftermarket pipe or back to stock?
    • By Atomusthenes
    • By motox88
    • By p5200
    • By jatho
      What is the best engine oil to use for the Suzuki King Quad - also any other tips and tricks I should know before doing an oil change on these bikes
    • By anthonyd256
