Hi guys, working on a 96 Sportsman 400, The 4WD Was not working, So I bypassed the shifter switch splicing the Red and Gray wires together, Now I have 4WD, Only problem is it only works in Forward Gear, Nothing in reverse, Even while pushing the Override button, What should I do? Thanks for any help!!!!
  • Admin changed the title to 1996 Sportsman 400 No Reverse
    • By Travis_Smith
    • By KSIM
      View File CFMOTO C-Force 400 service manual
      C-Force 400
    • By Kawasakibayounospark
    • By TravisM
      2001 bayou 220 KLF220A
      I'm at a loss here. Thanks.
    • By Sportsman500guy
