1996 Polaris Sportsman 500 4x4 Issues with high gear
By PIYIRIO
By alain
I just got this quad from my father in law need some tlc. Will need a new battery and does not know the battery PN as I don't have service manual. When my father in law had it , it uses lots of plugs, never got it service to verified why , he just buy an other plug and was good for a other 4 to 6 months .
Any one would havd answers would be appreciated. Thanks
By mans
Were is the neutral safety switch on 03' Kodiak 400 4x4 . How xan i check it to see if it's good for a no neutral light no power to machine. Ty
By Eisaks777
hello, i have bpr bombaradier rally 200 2007 which has a lot of gasoline in the oil sump, it is 4 stroke. Has anybody had problem like this and which can be the cause and how to fix it. i rode it today at -2 degrees celcius if it helps.
By Snick
^PINOUT:
5 6
2 4
1 3
