  • Ajmboy changed the title to 2005 Arctic Cat 500 Starter Click
Is that starter tight and making good connections? I hate to say it but if its new and clicking...sounds like you are getting power to it and the starter is just not engaging. I would probably tap on the starter with a small hammer and see if it starts, may have a low spot in that new starter. Try also jumping the starter to see if it engages.
    • By logray
      Hi all,
    • By OldATVowner
    • By tepin
    • By Shorty51
