So after my 400ex pep up (High comp piston, stage 2 hot cam, and some others), There was a malfunction with the rocker arm jam-nut; guess it wasn't torqued to spec. The rocker arm nut caused the lash to become too out of clearance and I bent a valve on a test rip high in the rpm range. There was no damage to the piston but only that valve, a couple dents in the head, and a completely destroyed valve guide. So I decided to take it upon myself (after watching kenoconnors race porting instructions and reading up on this subject) to port my cylinder head significantly. I had the head decked, cylinder honed and smoothed/polished the dome/exhaust port (intake wasn't polished but dimpled slightly to ensure fuel atomization). So after porting, decking the head, I had all valves and guides replaced/reamed, 5 angle valve job, and recut seats, then I installed xr400 gaskets (for higher compression), carb jets; 42 pilot, 175 or 6 main not sure, dynojet needle, k and n filter with no lid, enlarging of header ports and big gun eco slip on exhaust for a 450r, trx 250r coil (adds 1000+ rpm to limiter), 11:1 85mm piston, stg 2 hc with springs and retainers replaced, and polished rocker arms. I then replaced both sprockets one down in front and stock in rear, o ring chain, and 18in tires. There is a larger list of mods but these were the only ones affecting acceleration/performance. On the dyno, this quad put down 42rwhp and was estimated at 46 to the flywheel. Once again this was 42 to the wheel on the stock bore/carb size/header. All this was done at 16 yrs old. You may not be able to see it in the picture but peak whp was 42 on a mustang dyno.
Cool. I'm rebuilding my 03 400EX engine with a Pro-X piston kit and quadboss gaskets with Maxxis RAZR's(22 inch) in the rear and RAZR's in the front. It's got a Lexx full exaust system and renthal handlebars. I installed a 05 400EX carb and I find it gives it a bit more HP. I also have a question to whoever can answer: The front right wheel of my 400EX is leaning in towards the frame causing extra tire ware on that wheel. I'm pretty sure it's not the bearings because the wheel still rolls like new. Any help would be appreciated.😃
    • By joezee13
    • By middlebrookgt
      Hi All.  I introduced myself some weeks ago with my 2006 LT-F400F that needed a list of repairs including replacing the cracked generator cover.  It is back together as of last night and cranks up, idles and revs high pretty well.  Needs some fine tuning and stop backfiring at stop.
      The big issue is it will not go into gear.  I reassembled the insides with help from y’all’s posts.  The transfer selector moves from H-L-R, and the foot shifter moves thru the gears and finds neutral easily enough.  Before I tear it back open, the  transfer selector on top does not move as far as the repair manual says.  The diagram shows the shaft moving something like 40 degrees between L and H and 50+ degrees between L and R but it doesn’t move that far even though it finds the indent areas and moves well.
      Could this be the problem.  I aligned all the dots on the shifter gears inside and it appeared to not be binding anywhere.  I do hear the gears touching when I shift like they are trying to engage, but zero movement from the ARV
      Are there better/bigger photos somewhere that would allow me to be confident I included all the washers and bushings, etc?  If I had any doubt on parts that were laying inside after the cover broke then I purchased replacements from online stores.
      TIA for any input or feedback!!  Pics are from when I first took the generator cover off.
    • By Atomusthenes
    • By Ejwill
      I rebuilt the top end on my 2007 Honda Trx500fe. It ran fine right after the rebuilt. But now when I try to crank it it blows Bach through the carburetor. I held my hand over the opening for the intake air and it blew gas back on my hand. Can figure out what happened all of a sudden. It was cranking and was able to ride it running through all the gears. Now can get it to crank just blowing gas back to the air filter. Need help again. Starting to think I should have walked away from this one.
