WTB 1999 Kawasaki prairie 400 head
By kevinohio
By HighPlainsIT
My son's trying to get a 2003 Prairie 360 running. Over a year ago, he'd rebuilt the carburetor using a SHINDY 03-112 rebuild kit from JT Cycle & ATV, and it was working fine; however, when it wouldn't run recently, he took the carb apart and the jet needle was rusted in place. He cleaned that up as good as possible and replaced the jet needle with the old one that wasn't rusty. Now, he can only get it to start about 1 out of 5 tries, and when it does start, it won't run unless the choke's on. The spark plug's good and is sparking. It has compression. Any ideas on what he should try next or look into?
By 95kingQuad
By roggers
Hi everyone,
· Fast to download
· Cover both heavy equipment and ATV models
· Clear on licensing and safety
By DAVIDH
Hello my name is David, I have been riding for over 30 years ATV, dirt bikes, S x S you name it. I ride with a small group off and on though out the years. Currently, we have only three of us that have been riding this year and we are looking for more people to join us!
If you're in the Northern California area and looking for people to join on weekend and day trip rides send me an email: [email protected]! We have been to many OHV sites all over the state and we usually try to meet up for a ride once a month.
I look forward to hearing from you!
