What have you checked so far? If it cranks then battery and starter are good and you have a fuel, ignition, or timing problem. Start with looking at your fuel source and what I would do is spray a little starting fluid or fuel into the intake and see if it starts. If it does, you have a fuel starvation issue. You can also take the plug out and see if its firing.
    • By umax33
      i just got a 1986 honda trx 200 and the reverse and neutral lights don't work, i looked in the service manual and it says to remove two screws and the cover comes up and you can check the bulbs, the book does not show the two screws and i can't see them.Does anyone know how to get to the screws to check the bulbs. i will appreciate any help i can get...thank you
    • By Atomusthenes
    • By Trent Finnessey
    • By Tinkeringreg
