Anyone use Niche parts?
I’m looking for a top end kit for a Yamaha. I would like to see how well the engine runs before spending $6-$7 hundred on oem. Niche has complete kits from $1-$2 hundred. Anyone have experience with Niche or similar Chinese companies? -
2008 Can-am Outlander 800 R hard shifting issues
My 2008 can-am Outlander 800r is having hard shifting issues. Does anyone have a fix for this ? -
2006 Can-Am Outlander 400 XT Oil presure light is on
Hi everyone, Outlander 2006 400 XT i have replace the startor cover and right after i did that the oil light is on and not turn off, i check the wires and checked the oil level, everything seem to be normal quad is starting without any problem and rev just fine. i did not want to ride it since im not sure if it is faulty sensor or not so just be safe i did not let it run more the a minute or so. I have read in the owner manual that i need to clean the oil strainer every 200hr unfortun -
Anyone from South Florida?
Where do yall ride at in South Florida other than the MX track on Krome Ave? -
2005 Scrambler 500 4x4 valve cover bolts socket size?
Can someone please tell me what size socket I need to remove the valve cover? Thanks! 🙂
