    • By Tim Keiper
    • By Panupong Pradchaphet
    • By jhamrick75
    • By KdlH
      Following on from this thread;
      I've finally got around to pulling the clutch cover off to have a look at the shifter ratchet mechanism. The screw holding the pinned star wheel has come loose and the wheel flops about. Unfortunately the keyway on the shifter cam has broken on both sides, I found both pieces.
      Anyone had this problem?
      The keyway on the cam "ramps" out, so I'm thinking of making a slightly longer key with a ramp ground into it. I'll put it back together with retaining compound. It may not work but I think it's worth a try.
