Does rocking the bike back and forth work to let it shift? Try adjusting the clutch first and see if that helps. If not then it might be a different clutch issue, gears in the transmission binding, locking up, or even fusing. If not that then your shift drum/forks are most likely worn.
    • By flyinbrian365
      What's Covered:
    • By flyinbrian365
      What's Covered:
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      Polaris 110 EFI engine repair
      Brake system repair
      Polaris ATV torque specs
      AWD and differential repair
      Brake system service
      Sportsman 570 wiring diagram
