By Admin
By David Cameron
The small waterline insert for the hose that goes from the water pump cover to the thermostat housing has corroded off. I only need the insert on top and behind the thermostat housing that the hose goes over and can't find just the insert. It looks like it may be pressed in. I've have been told the entire motor housing needs to be replaced. The pic with the red line indicates where the hose and insert would be and the insert looks like the pic of the water pump Any ideas would be really appreciated.
By trootncsse
while troubleshooting an intermitant stalling issue we came across a fuel line rubbing on the frame where the fuel line comes from the injector and goes up to the pump. about 2" up from the injector the line runs next to the frame, and it appears that the coil plug wire has a rubber tab that may be is supposed to protect it from the frame. The bike has about 1400 miles on it and the line has some serious wear. it looks like over time it would be a hole. Ended up wrapping a piece of rubber around it to protect it. Will attach pics if allowed.
By Colonel
Can somebody help me? I am actually working on my three wheeler and I don’t know what to do: I can’t shift gears. I think it’s in reverse (because I can’t move forward but I can move backwards) but I can’t shift to any other speeds not even the neutral.
