2002 Polaris Sportsman 500 HO RSE  I sure could use some direction before I send my atv to the repair shop.
The atv will turnover but not kick in.  Here is what I have done so far:
changed gasoline/new carb/new fuel pump/checked throttle box on top of handlebars to make sure those two little silver gismos don't touch.
I replaced the spark plug which was working but bought a more expensive one.  I put gasoline in the spark plug hole and still didn't start.  Ether gives me hope but doesn't do the trick.
Bought a compression test and it registered between 50 and 60 I think.  I think that's low but don't know what it tells me specifically.
battery is good. Hooked up to charger while all this is going on.
Put some Marvel Mystery oil in gasoline ( a little)
No changes.  What else can I do?  If it's valves, etc.  it's gotta go to some repair shop.
Thanks for any help.  I may sound like I know what I'm talking about and I guess I do up to NOW
Beth
Edited by beld
    • By Elk
      2002 Polaris Magnum 325
    • By LashinWheeler
      Any help would be great,
      Thanks!
    • By flyinbrian365
      What's Covered:
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      AWD and differential repair
      Brake system service
      Sportsman 570 wiring diagram
