Help ....... I am not mechanically minded 😳 so any assistance you could give would be greatly received.  I was ridding the quad and it cut out, before it cut out it made a couple of pinging noise’s I think it was from exhaust ?
many thanks
😊 yes it would help.  It’s a Yamaha Bruin 359.  When I tried to restart the first time, with choke it started but then cut out when I gave it revs.  Electrics were fine as when towed back hazard warning lights were on.  Before it cut out, there were a couple of pinging sounds from the exhaust I think.  Also, when towed back I had the ignition turned on, so the hazards could work.  As I got to the top of the hill I was able to free wheel down, when I got to the bottom there was a buzzing noise coming from the steering column and a little smoke started coming out as well.  Did the free wheeling cause a 2nd problem?  Electrics are still working
Kind Regards
karen
free wheeling cause a probleme only if your brakes were applied as long as your were in Neutral positiion.
If it stopped, while working, maybe u had a fuel cut-out? check your fuel filter and carburetor
    • By Thekevinjb
      thanks
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
    • By carkivey3
