1995 Suzuki LT-F4WDX gas coming out vaccum hoses
By rjsummer
By David Land
I have an 05 King Quad 700 that has in the past had to have the stator replaced twice. For the past six months it has been down hard as I cannot get it to fire. I have replaced the coil (which is the code that came up) and now I have a friend replacing the stator. I want to see if the new stator does the trick. Drain the old fuel, and replace with 100% Ethanol free fuel, and see if that does the trick. The local Suziki dealer will not work on it as it is over 10 years old. So the nearest dealer is 90 miles away. The last thing I can do after that (provided the other fixes do not work) is replace the ECM/ECU. I also read that there was a recall on the ECM/ECU, so I need to check on that. All of the grounding has been checked, so if anyone has an idea, I would greatly appreciate the insight.
Kindly,
David
By exalrod
Hello All !
Could anyone help with this?
By davefrombc
COVID, record heat wave, fires, floods, deep freeze and more fires. Good riddance 2021. Have a Safe and very HAPPY NEW YEAR everyone. May 2022 make up for the trials of the last 2
