alfeye
kawasaki bayou 400 will not shift into neutral help
so someone thought they would adjust the clutch on this 98 bayou but the messed with the bottom screw and now it will not go in to neutral they say the tightened it all down and went for a ride then shut it off before putting it into neutral then the tried to shift it into neutral to start it and they couldn't get it to shift into neutral  it has not started.
Share this post
Link to post
  • Similar Topics
    • By Rick Shropshire
      Happy New Year all! Remember not to operate any vehicles while under the influence, you could get busted or worse, you could get hurt or hurt someone else who's playing it safe and end up in jail. Have fun and be safe.
    • By Ben Lennon
      Hi guys new to this forum and thought I’d jump on as I’ve just bought my first quad a Kawasaki bayou klf300c 89 model. It had starting issues when I bought it so I’ve gone thru and replaced the cdi, voltage regulator and starter solenoid aswell as rebuilt the starter motor after all this it was still free spinning on electric start so I pulled the stator cover off to find the fly wheel wasn’t spinning so replaced the one way clutch bearing put it all back together and still not engaging at all. I’m at a loss and looking for some ideas on we’re to look next to solve the problem
      cheers Ben 👍
    • By Andrew Baker
      I need help with wiring on a 1998 (I think, 10th digit of the VIN was W) Bayou. I'm not getting spark, I'm pretty sure it is due to grounds being off because the harness is pretty hacked as far as the electric start and charging system goes. I'm needing a good wiring schematic. I found one online and there are a few things that don't add up on it so I'm skeptical that it is really for my year and model. Any help would be appreciated. Thanks.
    • By Andrew520
      Got a good deal on an 89 bayou 300. Couple questions. First is in the picture I have posted. Note the two wires at the bottom of the pic (white and black/yellow). They were not hooked up to anything and Im not sure if they are supposed to go to the battery or somewhere else and what they are for.
      Second question is I had the carb apart for a cleaning. The vaccum operated slide has a spring under the cap with a plastic clip that goes inside the spring. Is there a proper location inside the spring for that clip. Right now it is just below half way inside the spring.
      It runs alright but keeps fouling the plug. Pulled the plug off, cleaned it and dried it off and it starts back up but not sure how long before itll do it again, last time it was about 20 minutes of riding and it bogged out and wouldnt start.
    • By JCH
      Hi there
      I am in need of a manual for my KLF 300 Bayou 4x2 . I've found others on here for the 4x4 model, but was wondering if I need a separate 4x2 manual. Does anyone know?
  • Similar Tagged Content
    • By Jeff Andersan
      1988 lt230 Suzuki
      Having problem with getting into neutral have to do it by hand to get into reverse keeps skipping into 2nd is there a adjustment I can do I'm new to this
    • By Reece K.
      I just recently bought a 1994 Yamaha Timberwolf 4x4 from a buddy who had the wheeler sitting in his garage for 7 years. I got it home and fired it up pushed it out of the garage and tried to shift it and it wouldn't shift. First it would click like it was shifting, but the wheeler wouldn't move and when I hit the gas it revved up like I was in nuetral. After trying some more it became stuck in 1st gear and wouldnt shift at all. But it later broke loose agian and acts like it is in neutral again. I took the motor off the machine to make it easier to work on.After asking friends they were convinced it was a clutch problem but after opening up the casing for the clutch I don't see anything out of the ordinary and am concerned that it may be a transmission problem. Any help would be greatly appreciated thank you.
    • By kb2112
      My 06 800 Outlander is getting more difficult to shift as it gets older. I have to rev the engine to get it to engage the chosen gear.
      Any suggestions to make it easier?
      Kb
