Sounds like the fuel line or gas valve at the bottom of the tank has a restriction.
I would take the fuel line off of the carb and put it in a can of some sort and open the valve make sure there is good flow.
If that is not the case then it would be inside the carburetor like a stuck float or something inside one of the jets.
Thats easy enough to take apart and clean out.
Was the bike sitting at all for a bit ?
Yes setting for about a year. I would start it once in a while and it starts right up. Starting riding it and it ran good for about a mile then die. If it sits for awhile it will start again but only for a short time. Thanks for the info. I took the fuel pump off but don't really think that is the problem. I turned gas  on and no gas in line, put it on reserve and had a full steam. That's the part I don't understand.
So I would drain the fuel out and take that gas valve off of the tank.  You can take it apart , usually a few screws that hold the thing together The main fuel port inside that patcock valve is prob clogged.
Be carfeull not to damage the rubber gasket inside.
I would also clean the carb as well. I have a feeling that float is not moving freely.
Might as well do it now while your at it!
Good luck!
Thanks for your info!! Have a great day
    • By RadRob
    • By Dumass
    • By Trent Finnessey
    • By neilroy87
    • By DPDISXR4Ti
      Thanks...
