Thanks for adding the manual, there are quite a few already uploaded here, two other sources for manuals can be found here
https://support.countrycat.com/?feed=recent
https://www.mymowerparts.com/pdf/Arctic-Cat-ATV-Repair-and-Service-Manuals/
This is a procedure I use to print out the schematics The diagrams don't print well on a regular sheet of paper due to their size so here is a procedure to get the diagram you need and make a nice print. This will be with utilities you can get for free (the best kind smile.gif
After downloading the large PDF of the schematics, go to this website here...
Tracker Software Products :: PDF-XChange Viewer, Free PDF Reader
Download pdf-xchange (its free)
Open the pdf file with this program. by clicking on the selections you can get to the exact schematic you need. Once its displayed do this:
File -> Export -> Export to Image
Select "Current page" , Image type "JPEG", choose your folder to drop the image, give it a name like "2006 400 auto" set page zoom to 100% and resolution to 300 or 400 dpi Then click export. You will now have a JPG of the page.
Next step is to go to this website...
https://www.posteriza.com/www.posteriza.com/es/index380c.html?lang=en_US
Download the program (free) What this will do is allow you to tke this large JPG and break it up onto several pages. I use 4 for the schematics. Its pretty easy to follow and I print them without a border. Print them out and use an old fashioned "cut & tape" and you will now have a nice large printout of your schematic.
Usually 4 page print is enough to make the diagram readable.
Mike
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      Polaris 110 EFI engine repair
      Brake system repair
      Polaris ATV torque specs
      AWD and differential repair
      Brake system service
      Sportsman 570 wiring diagram
      Sportsman 1000 wiring diagram
