warrior 350 is a 2002 it has a lot of custom features and after markets stuff that will stick out when u see it that ive done to it the plastic and headlights is from a 94 I’ve also rebuilt the top end of the motor with a new high compression piston & polished the intake and exhaust valve ports polished the inner area around the valves to keep carbon buildup from ever happening it has a lot of new parts it’s been rebuilt from the ground up all wheels are the bike runs amazing on handlebar dash pad has a black toggle switch for the LED lights on front bumper the rear axle is painting and the rear brake hub is painted blue so we’ll stick out and be very noticeable on the outlaw clutch aof lever the outlaw emblem is painted by me will stick out like a sore thumb it has custom rear Warrior decals on back fenders also has a monster energy ATV fx decal kit also has a lot of other stickers on it from parts that has been put into the quad I raced it a couple times would really like to have it back if it can be found I love a lot of money invested in the bike over the years I don’t have very much to offer right now for a reward
Parts list on stuff I’ve done to bike over time
Team Alba Front wheel spacers
All 4 wheel hubs painted dark purple
Front wheel hubs shields painted red
polished clutch cover
Tusk competition front bumper
Tusk polished competition nerfbars
Tusk rear brake rotor Tusk super bright white headlight bulbs
Tusk clutch kit
Champion Powersports 8809 spark plug
PRM products full rear swing arm skid plate
Fly racing purple handle bars
Fly racing handle bar grips
Artrax mxt tires
new Yamaha ignition coil
Dg RCM Chrome 3 piece performance exhaust system
Wiseco cam chain
Wiseco 10:25:1 high compression piston
Ek racing X O ring Drive chain
Outlaw Racing aof clutch lever
Yamaha grip seat cover black with a small silver-edge on the back side of the seat with Yamaha written in block letters
Led smoke brake light
Lower rear fender braces painted blue
Blue led light on the back side of the front bumper to light it up in the dark
Gearing is stock 13/40
Story on what happened
Went riding with my girlfriend and some of my friends a few months back we chained our bikes up so no one could take off with them after we left after we got done riding for a little while to get some gas and food to go back out riding again we came back and all of our bikes where took we’re only gone for about an hour
The post Help me find my warrior appeared first on Stolen 911.
View the full article
    • By quadmaniac
    • By DarkRider
      Hey Everybody,
      Durability is how long I can go without something breaking. OR how often things break with seeming not much of a good reason. Reliability is about the on-trail experience of having everything work properly as designed (i.e. Starting up and being able to get going without much issue, the 4wd drive engages without quirks, I can park it on a hill when needing to help someone else without worrying it'll roll away, etc) My Brute Force 750 is a perfect example of why Durability and Reliability were rated so differently. With durability, I really never felt like I've had anything break on the thing that was really from riding it. Which is great in that regard. But all of the things i've had to fix on it seem more so in it's design. The infamous KEBC code on the dash that refused to go away even after completely cleaning and lubing the KEBC and confirming it functions properly. Hard starting issues. 4WD requires you to roll about 10 to 15 feet to engage, so if you get stuck in 2WD, you're in a pickle. The infamous bus connector that goes bad and stops your charging system from working. I've worked through all of these, but these are all things I'd consider reliability issues that happen really at no fault of mine as I ride it pretty gently. Writing up this list has actually put a lot into perspective for me. The King Quad 300 really is a superb quad. The inclusion of the Super Low range provides stellar engine braking down pretty much any hill you can think of, it seems like it's unmatched. It has great gas mileage, and it's been dead reliable despite being a 1994. It's got 4x4 AND Diff lock, and the semi automatic transmission also help with not letting the quad get out of control down a hill. Plus it's more fun to me and gives me a bit more to do while riding. The biggest annoyance so far has been the parking brake. No matter how much I adjust it, it just doesn't seem stay adjusted after some time. I believe this might just be flawed on these models.  Also, parts availability is not the greatest on these since they don't make anything newer with any similar parts. Front axles are quite expensive, rear drive shafts go for $400 to $500 brand new, etc.
    • By joezee13
    • By middlebrookgt
    • By MOORETARHEELS
      I have a 2006 LT 80 done a top end rebuild and only have 80psi.  Any suggestions on what it could be.
