New arctic cat owner, I've read alot on the gauge issues, but let me say I have power, good ground, the aux also has power, the memory has correct voltage but no output of any kind. Only the LCD color works. I have also fully removed EVERYTHING and cleaned it all... what I still possibly have a cut wire knowing that I have good power to the back of the plug and good ground to the back of the plug but no outputs of any kind?
You can download the service manual and wiring schematics here:
https://www.mymowerparts.com/pdf/Arctic-Cat-ATV-Repair-and-Service-Manuals/
I would verify first that you do indeed have AUX power, popping that fuse would give you a blank display but it would still light up.
Two common issues to look at, one is a broken wire in and around the steering column. The schematics will help you verify which pin does what for the gauge cluster.
If it is the gauge itself, try this trick. disconnect both battery wires and connect them together, leave it overnight, then re-connect them, If the gauge isn't fried, this will reset it.
My bet would be a broken wire, seems to be a common problem in 2006 - 2009 Cats. I had a 2007 model that had serious harness problems. Was easy enough to fix with the schematics and using some spiral wrap and loom to protect it, never happened again.
Mike
    • By docdoug72
    • By neilroy87
    • By JMSwed
      Hi EVERYONE
      New member here
