This also looks like it might fit, mine has a metal screen with a foam surround and whatever foam gasket used to be there between the filter and the filter box has basically disappeared. The bike has not been well maintained :-(
Nigel, my 01' Kodiak has the same setup you are describing.  Here are the part #'s from Yamaha OEM parts site if that helps any.
  5GH-14458-01-00
(replaces part #
5GH-14458-00-00)
GUIDE $58.99 $40.13 7 In-Stock
11 1UY-14468-00-00 PLATE,ELEMENT FITTING $12.49 $8.49 10+ In-Stock
12 5GH-14451-00-00 ELEMENT, AIR CLEANER $19.99 $14.23 10+ In-Stock
I take that back, I did a search under your model and came up with these part #'s instead:
1YW-14458-01-00
(replaces part #
1Y
W-14458-00-00)
  1YW-14451-00-00 ELEMENT, AIR CLEANER $14.99 $10.19
GUIDE $59.99 $40.79
    • By docdoug72
    • By wanrep
    • By wanrep
      YFZ05YYXH
      YF05RH
    • By oxidized_black
