I am currently looking to buy a 2" lift kit for my arctic cat and was wanting to know if anyone knows if it is worth the 100$? Also if does it really lift the quad 2" or does it just say it?
For the wear and tear on your on your quad, I personaly don't think its worth it.
Puts way to much wear and tear on the entire drive train. Ball joints and cv joints to just name a couple things. Try to save you money down the road.
I agree. Those things sit high as it is.
    • By tepin
    • By toe420
    • By Callaway
    • By randyoct
      Will the top end of a 400 fit a 366 the price is so much cheaper
