What area of the bike did you find them ? There are breather hoses that do not go anywhere and just hang under the bike or go to the air box.   Did you recently change the oil and maybe put too much in ? You will get oil out of these lines if that happens.
  • 3 months later...
    • By quadnut20
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
    • By tflack500tbx
      Background,
      Any Ideas?
    • By kevinohio
    • By LCP92
