Welcome to Quadcrazy @Guillaume Cliche That some implosion damage.  Have you had any backfires ? That reminds me of an old bike I had that the timing was off a bit and the valves were out of spec also.   The engine backfired and and did the same thing to my floats. I would start there and see if the timing is off. That would also cause an erratic idle.
I didn't mention it but i also rebuild the head at the machine shop with new valves set the timing correctly change the cam chain and put a new gasket kit for the top end and intake gasket. Is a bad fuel pump can cause that or a bad vacuum hose ?
Sounds like you did the right job! The only thing I could think of was the timing unless your onto something with the fuel pump.   But the floats imploded to me equal a huge suctioning condition which could be the result of a poor fuel condition I would guess as if the engine is starving for gas.
But have you heard any backfire or as if the engine farted? Lol bad choice of words but best way to describe it!  Like it kicked back in the opposite direction ?
Yes it looks like the engine is starving your not the first to tell me that and for the backfires the first time i changed the float i remember seeing one you think that it causes the float implode ? Well i think the next step would be the fuel pump or inspecting the vacuum hose
    • By ButchM
    • By dkgg5755
    • By Joeguy
      Did a top end rebuild, honed .010 over, new piston, rings, valve seals, etc. When i re assembled i only had like 30 psi of compression but then after it sat all night i now it seems to have gained some somehow, there is much more resistance pulling it over and i even got it to fire for a few pops. Issue i got is that it makes a loud squeak noise through the intake i believe (goes away when throttled so something with carb area) and it seems to not want to run well. I took head cover back off and timing seems fine so im not sure if something is sticky and that's why i got some change over time or maybe the valve lash is messed up after doing all this, i did get another cam for it but i wouldnt think it would make enough difference to need to re lash. Any insight on next step would be appreciated, i will be looking up how to do lash on these because it is a very weird angle to slip a feeler gauge in.
      Actually cam is slightly off now that i look at the picture, thought it was good while looking in person. Hmm.
    • By Fww
      2014 750 king quad stalls sometimes when I touch or turn the handlebars  Anyone have a fix for this ?
    • By Ejwill
