Thank you I appreciate the advice
i did look at some of the connections I couldn’t find anything wrong with connections  does anyone have a good wiring diagram and troubleshoot charts
Also if I unplug the small black wire that comes from the harness to the starter solenoid  it doesn’t stall any ideas what that wire does ? Or is for ?
And it doesn’t always stall just randomly when you turn battery is good also getting 14.4volts when idling   When turning it drops to about 12.6volts this is all while idling
That sounds like  there is a bare spot  t5hat  shorts momentarily.  That would explain the  stall  and  voltage drop..  There should be a service manual  for that quad in the forum's download section.
The  black  wire may be from a safety switch to  prevent the starter from  running when the quad is in gear.
Gwbarm  I’ll attach a picture it attaches to the ground then goes into the wiring harness
davefrombc I looked I couldn’t find a manual on this atv
I unplug it to see if it would start in gear and it wouldn’t
and ok I’ll try to trace it this week some time
The closest manual I could find is one for a 2008
So I checked my grounds, I took the main ground completely off and turn the key to on and it still has ground the lights come on also  display I unplugged that power steering ground wire near the power steering unit and it still has ground as soon as unplug it at the battery it has no ground That means there’s a short in that wire somewhere, right ? Or am I missing something?
Edited by Fww
Could you take out the front fender and remove wire harnesses from their normal routing to see if you can still touch/turn without the engine getting killed?
    • By noticon75
    • By 88classic
      I have (2) sets of brand new plastics available for Honda Rancher 420 2014-2023. These are genuine genuine OEM Honda plastics. One set is white and the other set is green. The boxes these are in are too big to ship.(Unless you want to pay for it. If so, lookup your own shipping rates from 17325 and box size is 58"x35"x18").  $400
      View File 2014 Polaris Sportsman 570 EFI service manual
      Download the 2014 Polaris Sportsman 570 EFI service manual PDF for complete repair, maintenance, troubleshooting, and factory service information. This factory-style repair manual covers all major components including engine repair, clutch and transmission service, AWD systems, suspension, steering, electrical troubleshooting, wiring diagrams, brake systems, torque specifications, maintenance schedules, and more.
      Whether you are fixing common Polaris Sportsman 570 problems, performing routine maintenance, or doing a full rebuild, this manual provides detailed step-by-step instructions and diagrams for the 2014 Polaris Sportsman 570 EFI ATV.
      Popular searches related to this manual include:
      2014 Polaris Sportsman 570 service manual PDF Polaris Sportsman 570 repair manual Sportsman 570 wiring diagram Polaris 570 torque specs Sportsman 570 oil capacity Polaris Sportsman maintenance schedule Sportsman 570 troubleshooting guide Perfect for DIY ATV owners, mechanics, and Polaris enthusiasts looking to repair and maintain their Sportsman 570 EFI.
    • By toe420
