1987 Suzuki lt250 4wd Erratic Idle
By ButchM
By dkgg5755
By Joeguy
Did a top end rebuild, honed .010 over, new piston, rings, valve seals, etc. When i re assembled i only had like 30 psi of compression but then after it sat all night i now it seems to have gained some somehow, there is much more resistance pulling it over and i even got it to fire for a few pops. Issue i got is that it makes a loud squeak noise through the intake i believe (goes away when throttled so something with carb area) and it seems to not want to run well. I took head cover back off and timing seems fine so im not sure if something is sticky and that's why i got some change over time or maybe the valve lash is messed up after doing all this, i did get another cam for it but i wouldnt think it would make enough difference to need to re lash. Any insight on next step would be appreciated, i will be looking up how to do lash on these because it is a very weird angle to slip a feeler gauge in.
Actually cam is slightly off now that i look at the picture, thought it was good while looking in person. Hmm.
By Fww
2014 750 king quad stalls sometimes when I touch or turn the handlebars Anyone have a fix for this ?
By Ejwill
