Hey Christopher welcome to Quadcrazy, so glad to hear you got it running right.  The cooling system fan runs off a sensor that’s mounted in the radiator. On that sensor are two wires. While the bike is running take the two wires off the sensor and jump them together. The fan should come on.  If not then test the wires for 12 v. If you don’t have 12v then the fan power is obviously not there and it’s a mater of tracing the wires back to the source.  Keep in mind that some manufacturers have two points of protection in place, one is the fuse at the fuse block and the other is an in-line fuse that’s going to the fan.
If you do have power at one of the two wires going to the sensor and when you jump them together and the fan does not come on then your fan motor may be bad.
Thank you very much I will give that a try tomorrow and let you know
Ha we just  heard his story from another member who had a similar problem.  Turns out that when he was rebuilding the top end he put the coolant hoses on and reversed them by mistake.  I don’t know if you or anyone else worked on the atv but look there first.
The coolant hoses are correct I’m kind of thinking it is running rich or lean
I don’t know if that’s the case, could be but you would have a lot of black smoke from the exhaust?
Make sure your not running a hot plug and make any adjustments you think on the carb if you know where to set it and give it a shot. If not look for the usual suspects like the thermostat and water pump.  Check the coolant etc.
    • By kevinohio
      My cylinder is full of gas.i thought if carb was messed up.gas came out the overflow.had a cheap china made carburator on it.i ordered a factory used one.couldnt find a new one.also the fuel shut off isn't working right.and going to be needing the battery hold down and seat bracket.where can I get a used one?
    • By BillR94
      Thank you for your time
      Bill
    • By Asand211
      I've got a 1995 220 Bayou and the electric start does not work.  When I got it the machine was pretty rough but I was told it ran less than a year ago.  The key switch had been cut off and wires  twisted after the key was lost.  I bought a new ignition switch and repaired the wiring and it is working correctly.  It is in neutral and the neutral light is on when the key is turned on but I get nothing when pressing the start button.  I verified there is no voltage going to the starter from the solenoid.  The fuse in the solenoid is good.  Something I found that is odd is that I get positive voltage(12 volts) to the brown, black, and white wires that run into the solenoid when the key is on.  That doesn't make sense to me but I could be wrong.  I would appreciate any help I can get. Thank you in advance.
    • By Coyote251
    • By TravisCr
      I bought this from a buddy to plow snow up in the North Eastern Washington- its been getting oil in the water and I've been changing the oil often and adding collant as necessary-
      I've taken the stator cover off and I'm looking at the Oil Seal and water pump seal and they look good- Although I've ordered a factory oil Seal I'm looking at putting it in this afternoon-
      I don't have the factory service manual- am I suppose to Add RTV to the Stator cover Gasket? I've seen some folks suggest grease other suggest RTV?
      Any suggestions here- I'm trying to reassemble it tonight- I looked at downloading the manual but need to get up to 10 posts firsts it looks like-
      I appreciate any suggestions- normally I'm a jeep and honda dirt bike guy- but  I got a good deal on the quad and a plow so I went for it
      Its got a bit over 3K and runs pretty good- but I've had her tore apart for 3 weeks to figure out the oil in the coolant issue.
