Buyang atv eagle 100
Similar Topics
By Leski991
Hello,
I have read many forum topics on this matter but have never found a similar problem. So i bought a cheap ass quad thats got all sorts of parts on it. It's a 1997(if you look the date on frame) Kawasaki KLF(Bayou) 300 EUROPEAN Model (atleast I think, since I'm from Europe), the engine is 1988 if I'm not mistaken and the CDI is 1995.-2006. ( 21119-1447, 6pin ). My problem is that I don't have spark. I would diagnose the issue but connectors from CDI to wiring harness have almost all different colors and I'm not sure if they are connected correctly (pictures below). Pickup coil is putting out around 400 ohms and is pulsing. CDI is being fed 12v by one y/r wire that is coming to connector and with 12v to one gray wire which is coming from ignition switch ( quad actually doesn't have ignition switch so I'm not sure if gray should be supplying power or not). Stator looks good cause when crancking all three yellow wires put out around 5v AC. Neutral light is also on which means the switch should be ok, if it even matters. I know it's not the ignition coil since I get no power nor any kind of pulsing to G/W wire that is coming to it ( and I even put another one on there just to check an it ended with the same result). I'm nowhere near proffesional around this type of stuff so any help would be amazing.
By JacobSlabach
Hey just picked up another scrambler 850 was told the tps was bad. This atv has been beet to hell. Wiring has been tinkered with the crankcase has been replaced recently and the motor rebuilt (can see horizontal scores thru spark plug hole where it’s just been honed out and rebuilt)
my guess is it was ragged out till the motor blew a rod and rebuilt but the clown that did it couldn’t get it to run again and sold it. When I bought it it would pulse and smoke black at idle and die with throttle.
New tps installed and it won’t run period. I went to celebrate it and I’m getting 5 volts on 2 of the 3 wires running to the tps. Is this normal and if so how should I celebrate it?
By sammyshin
Hey so i have a 1990 bayou 220, and its missing the wiring harness so i went online and bought a bayou 300 wiring harness by mistake. Will it work if i use the 220’s cdi box and ignition coil?
By KDawgFPC
I have a 2004 Kawasaki KLF300. I’m not sure What is the black/yellow, brown, and red wire wrapped together in the wire hornets of a klf300. I got it used and notice some wires not connected. They are located in the front area
The reason why I am asking because I’m having issues with it firing up. I cleaned the carb put new spark plugs and gas.
By John Torbus
I am trying to figure out what the resistors do in this circuit. From what I have read in the manual the head light/tail light circuit is A/C. I am adding LED headlights/taillight so I want to convert it to D/C. My assumption is the resistors in the circuit bleed off some power since the incandescent bulbs are low wattage. Any input would be greatly appreciated. I am not putting a Baja LED light kit or light bar, just LED bulbs in the stock location and a small cube flood mounted on the handle bars. I already have the LED bulbs installed in the stock locations but they flicker badly.
Cheers,
John
Pred 50 Wiring Diagram.pdf
