Hi guys and thanks for taking the time to read this...
I've took my sons quad apart to tidy it up and replace the carb.
Replaced carb sprayed exhaust etc.. And when I reconnect the battery I get no starter??
I tried charging the battery and replacing it again to no avail.. On the battery ground wire there are two wires that seem to be pressed into the same connector.
I have read about a reset button under the wheel arch but can't seem to get it to work.
Here's a screenshot of the two wires that I think have been fused together circled on a diagram.
Thanks in advance.
Dean.
Ok I thought you meant melted or burnt up.
It's most likely something simple that was overlooked on the reassemble process.
Take a look for that fuse i told you about first and then go back over your work step by step. Im thinking a wire got pulled out of a connector someplace.
Double check the kill switch and ignition as well.
Where is the fuse mate?
I could only find 2 and they were both sound.
How do I check the kills witch? I've replaced ignition but I've tried old one back in and it worked before but still nothing.
There should be one by the battery.   There is a round small relay. Usually right next to it is a fuse. Take a few pics and post them, we will point it out if its there. On some of the smaller atvs it different. I haven't looked at the manual but it should be there.
Have you located that fuse #3 on your diagram? And lastly some of those bikes had the emergency rip cord to shut it down in an emergency if you fall off the atv as well as a brake switch where you have to pull the brakes in to start.
It has the rip cord and the foot rake switch. I'll look when I get home tomorrow mate thanks for all your help.
And yeah I've located fuse 3 it looks fine.
She's all back up and running there's a block with two fuses in... This fuse kept blowing the 7.5 fuse.
Turns out there was a wet connection in the black thing so I cleaned and dried it and she fired up and is now running like a dream. 😁😁 Thanks boys.
    • By logray
      Hi all,
    • By LMI
    • By HoldenBoy
      Hi all,
    • By crankin
