So here is the newest project in the garage, a '99 400EX.  Came with full belly pan, DMC Alien exhaust with dual header, few other little fun additions.  Only down side here really is the stupid Chinese carb, but it is what it is.  Only paid $800 for it and it runs like a scalded dog.  70MPH on the top end, verified with a truck behind it and you have to fight it to keep the front wheels down through 4th.
Just go through it and fix all the little issues. My oldest was wanting to do some flat track racing but it may stay more trails oriented. We have another one a little newer that was lowered and what not to flat track but its about worthless on everything but flat ground.
    • By joshualutz
    • By USRaider
      Hello all!
    • By marlon smith
    • By tin
    • By JBuckeyeJ
      I got the old thumper going.  My best guess is it sat in a barn for the past 10 years.  Now that I know it runs, it’s time for a valve adjustment and  tracking down a clutch cover.
