1999 Sportsman 335 with bad fan controler
- [[Template core/front/widgets/relatedContent is throwing an error. This theme may be out of date. Run the support tool in the AdminCP to restore the default theme.]]
Similar Topics
By PeteSaracen
Im fixing up a beartracker 250. Starts right up with screwdriver to both solenoid terminals and pull start. Doesnt start at all with electric start button. Neutral light and reverse light come on when the atv is running but when it is off and the key is turned to on position, no lights come on. When button is pressed to start, nothing happens. No click in solenoid, nothing. Not too experienced with the electrical components but I have tested a few things. The Front stop switch assembly cable was broken so I replaced that hoping it would fix my electrical problem to the key bevel but still nothing.
By tatjeff
can anyone help me figure out year and on my grizzly i have no clue rode many of them very first ever owned
By Mike Johnson
Does anyone know what the 3rd item is behind the battery on this ATV ? I know 1 is the, solenoid1 is the CDI box, what is the 3rd.
By Ted Aregi
I've got a king quad 750cc has anyone converted the fuel pump relay to a stronger fuel pump relay on there king quad?
