1999 Kawasaki Bayou 220 Wiring...what a mess
By tflack500tbx
Background,
Any Ideas?
By Arizona
By Peisledder
Hello, can someone help me? I have a MAP error code 102-3, and the MAP has 4 wires: light blue, orange, purple, yellow. I’m getting different results on what the wires are. I don’t have wiring diagram. Can someone confirm which is ground, 5v, MAP, and Temperature?
By kevinohio
By Gtc4d
Thanks.
Todd
