Hi Everyone - Need some help.
Got a nice little 220...clean machine. wiring is a mess. I have a diagram however, the one I have has 4 wires coming from the ignition switch not 2 like mine. So, I cant trace wires properly.
There is a white one that runs to the Solenoid, and a brown wire...from the Ignition...I dont know where its supposed to go. Also, on the Solenoid, there are 3 wires..W to ignition, B to start relay and B/Y runs up to the front of the machine...and is not plugged into anything...and there isnt a "Mate" missing it. How do they plug into the 4 open shovels by the 20A fuse?
I'm pretty sure my Lights and start switch/Lights are correct.
Problem I cant get anything...new battery...cant get the start button to work, cant get any power to the lights or switches...so I know something is not grounded or..
Any advice would be greatly appreciated.
Tom
  • Ajmboy changed the title to 1999 Kawasaki Bayou 220 Wiring...what a mess
Sorry it took so long. I have a 2000 bayou. Just white and brown from the key switch. On mine the white wire comes from the 20A fuse to the keyswitch. Keyswitch turned on routes power through the brown wire to the starter relay.  When the starter button is pushed it closes the circuit to the starter relay and the black wire from the through side of the starter relay is jumped through the engine on /off switch through the red /yellow wire to the CDI which then distributes it to the starter.
    • By jimbo69
      my outlander 800 sometmes starts and does good ouker times starts but will not idle .any one else have same problem?
      How come i cant download manuals i was told this is a good spot to find one for my lt230s quadsport.
    • By tflack500tbx
      Background,
      Any Ideas?
    • By Arizona
