Quad starts fine and revs fine in my back yard. On a test ride it falters badly. No power. I have cleaned and rebuilt the carb, cleaned the fuel tank, installed new fuel filter, changed fuel line and cleaned the air filter. Any help would be appreciated.
Did it run fine and then one day not?  Did you rebuild the top end and maybe get timing off a mark?  What does the plug look like?  Did you clean the jets out with a bit of wire or torch cleaning tips when you cleaned the carb?  How does the diaphragm look on the throttle slide?  Any holes in it?  Does it rev to WOT in neutral but dies under load?
Give us a bit more specific info to work with and I bet the group can help you find the issue.
    • By Fonne
      Hi
    • By mehim
      Hi everyone, first and foremost, I want to thank everyone for all the help I've received. I am so glad I found this community. I also wanna apologize if I'm spamming the forum, I come up with questions as I go, I guess lol. So when I got my Recon, the air box was missing the lid, held together by zip ties, and the filter was ripped and nasty. I have since ordered a new air box assembly. It comes with everything: the box,  lid, and filter ( the insert and the foam), and all the hardware necessary. This is the first time I've seen a metal filter inside a foam filter lol. However, my question is, I have read that you have to oil these filters? Every time I read it, it was always skimmed over, and I could not remember where I had read it. Is there a certain oil needed for this? Is the filter washable and reusable? Do I just stick the filter in oil, lol? Sorry if it sounds like a dumb question. Thanks in advance, y'all!
