Riding last week and the machine shut off, towed it back to camp and discovered that the ignition fuse was blown.  Replaced the fuse and as soon as I hit the starter button it blows again. Is there any component that might cause the issue?  I checked the wiring runs and could not find any wire breaks. Using multimeter I see a short on the orange wire from the fuse block.
Find the orange wire other end, where does it go. Disconnect it and see if the short goes away. If it does keep going, if it doesn't then between the fuse block and where ever it ended is your short. With out seeing the wiring diagram this is the only help I can give you at the moment, sorry
    • By Joeguy
    • By logray
      Hi all,
    • By OldATVowner
    • By Dsluder
