My dad's Fourtrax has no front brakes when you first pull it, but when he pumps it 5 or 6 times it does just as good as a new one. We had the brakes bled and it didn't do any good. Any ideas?
Sorry it took so long to reply, but thanks for the help! Oh, and it's not leaking fluid, so it could be any of those things ZacUSNYR mentioned?
Thanks for the replys!
  • Admin changed the title to Honda Fourtrax Need some help with brakes.
    • By TomJulio
    • By Adamb2025
    • By TomJulio
    • By Olchap
      Thank you,
      Olchap
