My byou finally got running after I rebuilt the carb. I took it for a trail ride, and finished by riding her pretty hard up a dirt hill. At the peak of the hill it dropped out of gear, and had to be pushed home. It will still start, and idle. When I apply throttle it revs really high, and no matter what gear it is put into, it will rev high and take a few moments after i release the throttle to wine down.
I have pulled the clutches out, and it does appear the centrifugal clutch is worn. I took the dremel to it, and tried to get some relief lines back in there.
Before I reassemble and test, does anyone know if this is even a clutch issue? or possibly transmission/case related.
also can I make a gasket out of cardboard and Indian head just to test after  cutting grooves in centrifugal clutch?
    • By Tinkeringreg
    • By Dumass
    • By Trent Finnessey
