1999 Yamaha Big Bear 350 Can’t Get Into Neutral
By OldATVowner
By HoldenBoy
Hi all,
By jeffrocdx
By wilmpie
hi everybody
I have a kymco mxu 250 automatic from 2006 250 cc that keeps going forwards or backwards when i shift backwards or forwards an then shift to neutral .
if i shutdown the motor and push the quad and restart then its in neutral and don't go forwards or backwards, i already checkt if my motor is running good stationairy .
what can it be or what can i do to fix this?
thanx in advance
p.s. Sorry for my bad english it's not my first language.
By T37Mark
