1999 Yamaha Big Bear 350 Can’t Get Into Neutral
By HoldenBoy
By jeffrocdx
By wilmpie
hi everybody
I have a kymco mxu 250 automatic from 2006 250 cc that keeps going forwards or backwards when i shift backwards or forwards an then shift to neutral .
thanx in advance
By T37Mark
By joezee13
