1998 YAMAHA BIG BEAR 350 4WD-replacing brakes
dctaz37
I adjusted the brake handle and when I engage the brakes the handle still has a lot of resistance but the brakes don't stop well.  I saw another post here with the same issue and they suggested to adjust the shoes. I took my brakes apart and the adjusters are seized. I tried to figure out how they work so I loosened the side that is in the wheel cylinder and removed it but there is no thread to go in or out so I don't know how they work. I sanded the pads a bit to get them rough. Reassembled and same issue.
I replaced the shoes on back and both fronts. Seems better but still not great. The adjusters on the front were all seized and a real pan to free up. One ended up getting a warp so it doesn't work very well now. I got it together as well as I could but really hard to adjust the shoes. Especially when it is full time 4x4 so when you turn the wheel you get the resistance of the other wheel etc...
    • By Roofus
      I cant seem to find what this part is called. Can anyone point me in the right direction? I must be misinterpereting the parts catalog or something? I dont see it in the rear axle section. I think it may be in the rear brake assembly section? click link to view picture.
      [removed broken image]
    • By Otter9099
    • By mehim
      Hi everyone.
