2001 Yamaha Grizzly Head Protection
By kiriyaaoi
By GrizzlyRider
The 2024 ATVs are out and I was just looking at the websites for Yamaha and Suzuki. The Grizzly and King Quad have come a long way, probably two of my favorite quads over the years. Both of these come with power steering but I almost like the King Quad styling a little more. The plastics haven't changed much over the years either, mayeb a little more rugged. The King Quad racks are more like the Polaris plastic racks (I think they were the first to introduce these) but on a closer look, I think its just plastic covers over the traditional metal racks. The Grizzly still keeps the old style metal racks. I like the display/instrument panel on the Grizzly more.
2024 Suzuki King Quad
2024 Yamaha Grizzly
Thoughts on these two? Here's a pretty good comparison of both 2023 models. I didn't know some of these things like no seat latch on the Grizzly and hydraulic rear brake vs cable. Good video to watch if you are consideting these:
Grizzly 700 vs KingQuad 750! 2023 Full Shootout!" width="200">
By Starsat
The choke lever doesn't stay in position on my 2001 Yamaha Kodiak. The model is YFM 400. I have to hold the lever to the choke position manually for some reason. Any Ideas as to why?
By Grizz10
Hi everyone, looks like a busy place.
Is there a free download available anywhere for my machine?Im not having much luck, as the key word here, is free. Thank you
By huntindog
TIA
Similar Tagged Forum Content
- 20 replies
- 2,472 views
- 8 replies
- 831 views
- 2 replies
- 1,022 views
2019-2020 Yamaha Grizzly 700 EPS 4WD Service Manual
By GrizzlyRider,
- grizzly
- grizzly se
- (and 1 more)
- 0 replies
- 1,275 views
By GrizzlyRider,
- grizzly
- grizzly se
- (and 1 more)
- 0 comments
- 3,323 views
